Robin
Message 1 of 15
Powerline adapters
Hello.
Just ordered a Youview box today, along with a separate TP Link mini router from PC World. However, looking at my order it seems as though there is a pair of Powerline Adapters included.
Can anyone tell me which make of adapters are being shipped with the Youview box at the moment?
Thanks.
Robin.
14 REPLIES 14
Message 2 of 15
Re: Powerline adapters
The are made by Simpler Networks and the model is the HP200PT64 as seen here.
http://simpler-networks.com/shop/article_110/HP200PT64.html?sessid=qM0Yii8fABqJT9h25NalSrW2dBuvaTa3W...
Robin
Message 3 of 15
Thanks for that bit of info.
Distinguished Guru
Message 4 of 15
That's good to hear that BT no longer use the HP200PT64BT2 ones:)
(note the BT2)
If they're just the HP200PT64's then there should be a disc sent with them, if they're the BT2's then BT have had them locked down:(
-+-No longer a forum member-+-
Message 5 of 15
Just checked again. Mine are labelled HP200PT64BT. No disc was supplied. Not actually using them waiting for my infinity FTTP install tomorrow because when the engineer has left I will be moving the  furniture around. Hopefully they will work OK.
Distinguished Guru
Message 6 of 15
Nah, the BT ones don't have a disc, nor can you tweak them like you could with the previous comtrend ones:(
Robin
Message 7 of 15
I realise that the adapter next to the router needs to be into a main socket, but can the second adapter be plugged into an extension lead?
JXHogan74
Message 8 of 15
It DOES work but tbh it's not worth it unles you ABSOLUTELY have to as the speed and error correction required will be a problem....if you are doing it may I suggest an investment in the best extension lead you can find...
Distinguished Guru
Message 9 of 15
Provided that the adaptor is not one that incorporates surge protection as this will block the signals passed through the adaptor.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Robin
Message 10 of 15
I may be better off using the TP-LINK TL-WR702N mini router I have on order from PC World.
