Message 21 of 26
Re: Pretty poor broadband speeds compared to my old talktalk
Hi
I have done a new speedtest at 15.30 this afternoon, and router settings at 15.55. Posted below.
I will do one final check this evening to see how it is during peak times, then I will mark this post as solved. Thanks to you guys, great help/advice!! If you compare this router reading with my original I think it speaks for itself now, after having taken out the orange wires, and tidid up a little, errors are very few, especially compared with my original.
Thanks guys for all the help!!
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 08:09:14
Downstream:19.25 Mbps
Upstream:1.127 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):5.4 dB / 6.2 dB
Line attenuation (Down/Up):9.5 dB / 4.8 dB
Output power (Down/Up):18.4 dBm / 11.5 dBm
FEC Events (Down/Up):2232 / 73
CRC Events (Down/Up):3 / 3
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):10 / 4
Error Seconds (Local/Remote):3 / 3
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
 Download  Speed
 15319 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 15319 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :19715 Kbps(DOWN-STREAM), 1153 Kbps(UP-STREAM)
 IP Profile for your line is - 17393 Kbps
2. Upstream Test: -provides background information.
 Upload Speed
 791 Kbps
0 Kbps1153 Kbps
>Upload speed achieved during the test was - 791 Kbps
 Upstream Rate IP profile on your line is - 1153 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
Tags (4)
Message 22 of 26
the changes you have made to your wiring really has significantly reduced your error count ans should make your line more stable and btspeedtester is looking good
Message 23 of 26
HI looking very good well worth the effort to sort out the internal wiring it goes to show what can be done
Message 24 of 26
Ok, last post here me thinks.
I have been playing lord of the rings online for past 3 hours (which is quite a hungry MMO), and here are my router and speed test settings (@20.09 this evening). Very happy with speed results, and at peak time as well. Very happy bunny now......
Man Happy
Compared with original post much much much better!!! Errors have now dramatically reduced, and speed seems a bit more stable during peak time...... Case closed!!
ADSL Line Status
Connection time:0 days, 12:04:07
Upstream:1.127 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):5.3 dB / 6.2 dB
FEC Events (Down/Up):3998 / 93
CRC Events (Down/Up):6 / 3
HEC Events (Down/Up):16 / 4
Error Seconds (Local/Remote):5 / 3
 Download  Speed
 15633 Kbps
0 Kbps21000 Kbps
 Download speedachieved during the test was - 15633 Kbps
 Upload Speed
 891 Kbps
0 Kbps1153 Kbps
>Upload speed achieved during the test was - 891 Kbps
Message 25 of 26
Great new glad its all ok now If you ever need any further help or advise please post back
Message 26 of 26
good luck - enjoySmiley Wink
