Message 1 of 6
Private Address-MAC Randomisation
I am aware of the not so recent changes to iOS14 and the MAC Randomisation but has anyone found a way to use air print?
Having issues printing to a HP Envy 4500 (latest firmware) after the iOS 14 changes last year, the only way past it so far is to turn off "Private Address" in the iOS Wi-Fi settings, wondered if there is a setting on the Smart Hub 2 that could be changed
5 REPLIES 5
Message 2 of 6
Re: Private Address-MAC Randomisation
@Eiehler
Why would you not want to turn off  Private Addressing on your home wifi?
I can understand maybe leaving it on for other wifi access points but not your home one.
Message 3 of 6
By default it's on, it'll mean switching it on/off or more importantly, remembering to switch it on when away from home. Hopefully there'll be an setting in the next home hub that can deal with it.
Message 4 of 6
Why would the home hub have to fix some marketing gimmick unnecessarily introduced by Apple? Nobody else does it.
Message 5 of 6
@Eiehler
It's switchable for each & every wifi connection so on my home wifi it's off but when I connect to any other it's on unless I specifically turn off for that specific connection. It's not an across the board on/off switch.
Message 6 of 6
That's good to know, thanks.
