NoelRoye
Newbie
Message 1 of 4
Problem connecting Airport express to Infinity Home Hub3
Recently had Infinity Home Hub3 connected and I am unable to connect Apple Airport express or Time capsule to the hub. Can anyone help as it is driving me mad.
NoelRoyeMan Sad
3 REPLIES 3
jjgraphics
Recognised Expert
Message 2 of 4
Re: Problem connecting Airport express to Infinity Home Hub3
The Apple Time Capsule is a router in its own right and replaces the HH3, it does not connect to it.
Remove the HH3 and connect the Ethernet cable (red ends) from the white Openreach modem to the WAN port on the Time Capsule and do the setup as in the Apple manual.
Airport Express can then be set up to work on the Time Capsule network.
jimmynitcher
Message 3 of 4
any idea what you do if you aren't using Time Capsule?
I've got 2 Airport Expresses
thanks
milo
Newbie
Message 4 of 4
Hi am am having the same problem as above. I have BT infinity with a Home Hub 3, and I am unable to connect my airport express to it at all. I used to have O2 broadband and it was fine with that.
Any help much appreciated!! Smiley Happy
