Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hello, i can not connect with EA servers from origin on my PC. I trace my route to EA servers, by Ultima Online Trace Utility and it shows me i have 100% packet loss with 3 hosts, it looks like i need to open some ports.
I already open ports like this https://scr.hu/BmOl94 and i still have this problem with connection.
This is the screen from UOT: https://scr.hu/dD0r0X
i'm connected to router by LAN cable. what's wrong ? why i have there 100% loss packet ?
Solved! Go to Solution.
The trace looks ok inside the BT network. Some routers are configured not to respond to ping so can be a normal result. Your problems begin once you transfer to the Akamai network. Latency increase. The EA server 159.153.226.65 is not responding here either. I don't use a hub so that's not the issue. Looks like an EA problem.
You only need to open inbound ports not outbound ones. What are you trying to do exactly ? The only reason on origin you would need to open ports is to host a game or join in a game that uses a Peer 2 peer connection type(Not many do P2P).
The problem starts as soon as you hit the EA network. 159.153.92.10 unreachable.
Latency increase at 4.79.23.202 (Level 3 Communications, Inc. Colorado)
PS C:\Users\Administrator> tracert 159.153.226.65
Tracing route to fert01.abn-iad.ea.com [159.153.226.65]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 7 ms 7 ms 7 ms 217.32.142.107
3 7 ms 7 ms 7 ms 217.32.142.158
4 13 ms 13 ms 13 ms 212.140.206.10
5 27 ms 16 ms 20 ms 213.120.162.65
6 30 ms 20 ms 13 ms 31.55.165.107
7 16 ms 13 ms 13 ms 109.159.250.48
8 21 ms 23 ms 23 ms core2-te0-13-0-15.ilford.ukcore.bt
9 24 ms 24 ms 24 ms peer5-te0-0-0-17.telehouse.ukcore.
10 24 ms 23 ms 23 ms t2c4-et-8-1-0-0.uk-lon1.eu.bt.net
11 21 ms 20 ms 21 ms 5-2-1.ear2.London15.Level3.net [21
12 * * * Request timed out.
13 95 ms 96 ms 95 ms 4.79.23.202
14 * 159.153.92.10 reports: Destination net unreachable.
The Dublin server result.
PS C:\Users\Administrator> tracert 159.153.34.179
Tracing route to 159.153.34.179 over a maximum of
1 1 ms <1 ms <1 ms 192.168.0.1
2 8 ms 6 ms 6 ms 217.32.142.107
4 13 ms 13 ms 13 ms 212.140.206.18
5 13 ms 13 ms 14 ms 213.120.162.65
6 15 ms 14 ms 14 ms 31.55.165.107
7 13 ms 13 ms 13 ms 109.159.250.54
8 23 ms 23 ms 23 ms 109.159.255.217
9 22 ms 21 ms 20 ms core3-te-0-9-0-2.f
10 23 ms 23 ms 23 ms 213.137.183.34
11 21 ms 20 ms 21 ms ldn-b3-link.telia.
12 21 ms 26 ms 20 ms ldn-bb3-link.telia
13 30 ms 29 ms 30 ms dln-b1-link.telia.
14 34 ms 33 ms 34 ms bioware-ic-147166-
15 * * * Request timed out.
16 * * * Request timed out.
All the way to:
30 * * * Request timed out.
The Netherlands server result.
C:\Users\Administrator>tracert 185.179.200.210
Tracing route to hosted-by.i3d.net [185.179.200.210]
3 7 ms 7 ms 7 ms 217.32.142.174
5 33 ms 35 ms 22 ms 213.120.162.65
6 14 ms 14 ms 15 ms 31.55.165.107
7 14 ms 13 ms 13 ms 109.159.250.50
8 20 ms 19 ms 19 ms 109.159.250.148
9 23 ms 24 ms 23 ms peer5-te0-10-0-12.telehouse.ukcore.bt.net [62.17
2.102.33]
10 23 ms 23 ms 23 ms 195.66.226.41
11 179 ms 179 ms 179 ms ae-2.cr-01-lhr.uk.seacomnet.com [105.16.35.1]
12 179 ms 179 ms 179 ms xe-0-1-0-6.cr-01-cpt.za.seacomnet.com [105.16.11
.177]
13 178 ms 178 ms 179 ms xe-0-0-0-8.cr-01-jnb.za.seacomnet.com [105.16.9.
177]
14 177 ms 176 ms 176 ms xe-1-0-0-0.er-02-jnb.za.seacomnet.com [105.16.29
.10]
15 179 ms 177 ms 179 ms ae-2-156.customer-gw-teraco-data-environments.er
-02-jnb.za.seacomnet.com [105.22.41.38]
16 176 ms 177 ms 176 ms 196.10.98.34.teraco.co.za [196.10.98.34]
17 181 ms 180 ms 180 ms hosted-by.i3d.net [185.179.200.210]
Trace complete.
Some reports online of EA having issues over the last few days.
Like I said the only time you need to forward ports is if you require people to connect inbound to you. For battlefield 1 I believe the servers are hosted so no player hosts or peer 2 peer. The ports they've asked you to forward are for HTTP/HTTPS ie the ports used by the origin client connecting out to origin so you can view information. if you are using a HomeHub then the ports required outbound will be open as standard. Have you tried rebooting both your router and your PC?
