stonermc
Message 1 of 2
Problem with BTNetProtect Plus
Hi,
About two weeks ago there was a major update from McAfee .. the next day my pc kept locking up, I couldn't do anything with it.  So I had to open in Safe Mode and restore registry to a previous date before the McAfee update.
That got my pc working again.  Unfortunately, ever since then my NPPlus flashes up every 30 minutes or so, saying either that my Computer & Files are not protected and/or my Internet & Network is unprotected.  I press Fix and the problem goes away.. but temporarily.
If anyone could advise me, that would be most appreciated.
I use windows Vista... for my sins.
1 REPLY 1
chrisadam12
Newbie
Message 2 of 2
Re: Problem with BTNetProtect Plus
I found an article that has direction to fix the error your receiving:
http://support.microsoft.com/kb/931849
I suggest turning off the McAfee software temporarily while performing the troubleshooting steps in the article.
If it resolves the issue with Defender, you should then be able to turn off Defender and use McAfee with no issues.
_________________________________________________________________________
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups [url= http://oceangroups.org/]seo pecialist [/url]
