Nc35
Message 1 of 5
Problem with Master socket - Please help
Hi Everyone
Moved into a new home with BT Broadband.
Having a nightmare with the broadband being slow or running quite well. Speeds between 0.3Mbps and 11.4Mbps. Upload rate never rises above 0.8Mbps.
BT are warning of a £130 charge if an engineer come out and finds a problem with wiring within the house.
So anyone know how the master box should be wired? As I understand we have the newer socket with built-in filter.
There are two tiny wires one orange & one white going into sockets B & A on the openreach side of the socket.
Is this correct? Is there anything else that I can check?
Thanking you in anticipation
4 REPLIES 4
peterh0001
Message 2 of 5
Re: Problem with Master socket - Please help
Hi
You need to plug into the test socket (using a microfilter as you are bypassing the filter) and run a BTW speedtest and a quiet line test and post the results.  Also post your router stats.
That will allow the forum to see what the problem is.
Nc35
Message 3 of 5
Thanks Peter
Should have mentioned that I have removed the faceplate and tested with a filter with the same results.
Not sure what a BTW and quiet line test are will have a google.
Nc35
Message 4 of 5
Learn something new everyday lol.
Quiet line test has a low whistle sound in the background.
BTW test
DL 4.2Mbps
UL 0.13Mbps
Ping 0.00
Hope this helps
Webby
Message 5 of 5
You need to report a noisy line fault to 0800800151
Once the noise issue is fixed, the broadband speed will return.
Don't mention issues with your broadband when you call to report the noisy line.
