Message 1 of 1
Problem with connecting to Disc
Hi All
I have BT Halo 3+ and 2 black discs, I have an internet radio which works fine and connect to my broadband wifi. The only problem is it insists on connecting directly to the main hub even though it is located virtually next  to one of the booster discs in a back bedroom . I can manually reset it and it will then connect to the disc but next time it resets itself which it does from time to time if it loses the radio connection,  it will then consistently connect to the hub and not the disc. Is there anyway to rectify this?
