kenkyle236
Message 1 of 17
Problem with master socket
I was recently on the phone to a technical adviser, and I was told to open up the master socket to connect my broadband to the test socket, however there was no test socket. The advisor told me to put it back, and I carefully put it back, but then one of the connectors on terminal 5 fell off and now my connection is ruined! I don't know how to put it back and I've attempted to do a temporary solution.
The phone seems to crackle quite a lot and the broadband also cuts off if I move the socket.....
The wires looked very corroded and this was the first time I had opened up the master socket. Is there anyway I could get an engineer to replace the socket and how much would the charge be.
There is still the wire on terminal 2 that is still in place, just terminal 5 that has fallen off.
16 REPLIES 16
Message 2 of 17
Re: Problem with master socket
if you have no test socket and the phone line is noisy then you need to report it to BT Faults on 151 providing the noise is not caused by any internal wiring or equipment there should be no charge
kenkyle236
Message 3 of 17
Thanks for your reply john,
There is nothing making the noise, is just that the wire in the master socket bcame loose (Terminal 5) here is a picture:
Would this count as internal wiring?
Message 4 of 17
you should be able to push wire back into terminal 5 without need to engineer.  you need an IDC tool - just google
kenkyle236
Message 5 of 17
Ok thank you very much john 🙂 Will make sure I get one of these!
dfenceman
Expert
Message 6 of 17
Try stripping the insulation and use a pair of pliers, that's what some BT engineers do I believe.
Best regards,
dfenceman
kenkyle236
Message 7 of 17
Which one is the insulator?
Message 8 of 17
think it was insulation - the plastic coating but normally you just push the wire in with plastic coating on with correct IDC tool and it will cut through plastic coating to make the connection.  is that not how the other wire is connected?
dfenceman
Expert
Message 9 of 17
I said the inusalation, i.e. the PVC covering that insulates the wiring.  Stripping it and inserting the bared conductor with piers ensures a better connection.  Sometimes using the insertion tool does not always cause the PVC to be cut through and thi can also cause problems.
Best regards,
dfenceman
Message 10 of 17
Never had any problem dfenceman but I use a proper IDC tool not one of the cheap pieces of plastic
