Message 1 of 15
Problems im having
Hi all i been connected to BT BB since 2nd of feb. all went smouth, now im getting random disconnection after so many hours and sometimes can be 1 min then id get couple more disconnection in a row, ive checks quiet line test and line is quiet new micro filter installed. Ping to google and bbc coming soon..
14 REPLIES 14
Message 2 of 15
Re: Problems im having
Welcome to this customer to customer forum.
To enable forum members to help you, could you please read the web page that is shown below, which asks you to do a few checks first, and has some helpful hints.
When you have done that, please follow the instructions at the end, and post the results here, so members can offer advice. Thank you.
Speed and disconnections
Message 3 of 15
How do you connect your computer to the BT home hub?
Wireless N PCI Card
Regular disconnections when using the home hub 3?
 Was connected to IP for 17 days till problem came
Is your computer fast enough?
Yes high end amd 6 core cpu with ati 6790 and 8GB and plenty of space
Is there noise on the line when you make a phone call?
Nope quiet
If you need further help with this issue, then please could you post your BT Speedtester results and your BT Home Hub ADSL statistics, on the forum, and a forum member should be able to offer advice:
Download speedachieved during the test was - 11.71 Mbps For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps. IP Profile for your line is - 14.04 Mbps
Upload speed achieved during the test was - 1.15Mbps Additional Information: Upstream Rate IP profile on your line is - 832 Kbps
Hope this is enough info
Message 4 of 15
we still need your full hub stats
Message 5 of 15
Oh sorry, erm i using netgear dg834g v4
Message 6 of 15
This may help From
the web interface http://192.168.0.1
> Router Status
> "Show Statistics" Button
alternatively click this link --> Show Statistics.
Default username = admin, password = password
Message 7 of 15
System Up Time 03:38:12
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA804249142527502127831362001:15:10
LAN10M/100M444000210003:38:06
WLAN11M/54M142986781784403170262343303:37:58
ADSL LinkDownstreamUpstream
Connection Speed15918 kbps1276 kbps
Line Attenuation31.5 db15.8 db
Noise Margin5.8 db5.9 db
Message 8 of 15
Also can someone explain in my faults that open on my account it says "BT Retail Servers"?  what that mean?
Message 9 of 15
Did you report a fault?
Message 10 of 15
Nope i asked bt they said they raised it but i didnt know till i started having problems and they didnt tell me what sort of fault it is
