Mprice3024
Message 1 of 3
Problems logging in to wifi/Fon hotspots
Hi guys,
Seen a few people who have this problem but none of the posts state the solution.
The problem I'm having is that I cannot log into any BT Fon/wifi hotspots when I'm out and about. I keep getting a message that my username/password is incorrect.
I've checked that I'm opted in
The email is my primary one
The email address/password is correct as I can log in and check my emails just fine.
Any help would be brilliant.
Regards
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Problems logging in to wifi/Fon hotspots
Make sure you log into the site by clicking the BT Total Broadband link.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Distinguished Guru
Distinguished Guru
Message 3 of 3
DD is right, but you also need to make sure that you're using a btinternet.com email address; although BT Yahoo! will accept other domains (eg btopenworld.com), BT WiFi won't. Actually, you can just use the user name (the bit before the @) for BT WiFi.
