reevesi2
Message 1 of 2
Problems with BT WiFi app and BT Smart Talk
I can not get the WiFi app to work I can log in manually with my email I'd but this does not work for the app. I also tried to install Smart Talk but it will not run through initial setup. I have wasted weeks trying to get the idiots on the help desk in Puna to sort this out. I am of the opinion that my BT I'd which is a simple string set up 20 years ago is the problem how can I change this to my primary email I'd ?
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Re: Problems with BT WiFi app and BT Smart Talk
Hi @reevesi2,
Thanks for posting. I'm sure I can help get the MyBT primary ID sorted for you. Can you drop me over an email with your details? You'll get the contact the moderators link in my pofile.
Cheers
David
