Hi all,
I wonder if anyone can give me some help with this as I'm currently at a loss as to what the problem is. I have spoken to BT support but they were not able to help with 3rd party routers and directed me here.
I can successfully connect to the Internet using PFsense and running speedtests brings back the expected results, but after that is where issues begin.
If I try to download from my dedicated server in Germany, I am lucky to get 5Mbps.
If I download from my friend in Sweden I am lucky to get 2.5Mbps.
Even downloading from PFsense's own website gives me only 5Mbps but on my dedicated server I get 400Mbps so there is no bottleneck on their end.
However if I connect my BT Smart Hub back in place I can get 190Mbps from my server in Germany and 35Mbps from my friend in Sweden, and I can get good speeds from PFsense's website too.
I don't understand why I would get slower speeds to Germany/Sweden but still get full speed on speedtests simply by changing to PFsense rather than using the BT Smart Hub, unless there is some setting that I have misconfigured. PFsense is up to date and I have even tried a completely fresh install too to rule out anything other settings may have caused.
Here are the settings I am currently using:
PPPoE
Username: bthomehub@btbroadband.com
Password: BT
MTU: 1470 (default, and not entered also auto-negotiates to this value)
I have read some people using VLAN 101 but trying this results in no connection being established.
My advanced settings are all set to the defaults as I have no idea what I would change here. I haven't found any information online regarding those.
Here is my PPPoE connection log, in case this gives any further information that you may need:
Spoiler (Highlight to read) Dec 3 20:39:05 ppp Multi-link PPP daemon for FreeBSD Dec 3 20:39:05 ppp process 22871 started, version 5.8 (root@pfSense_v2_4_4_amd64-pfSense_v2_4_4-job-09 11:56 16-Nov-2018) Dec 3 20:39:05 ppp waiting for process 70115 to die... Dec 3 20:39:05 ppp caught fatal signal TERM Dec 3 20:39:05 ppp [wan] IFACE: Close event Dec 3 20:39:05 ppp [wan] IPCP: Close event Dec 3 20:39:05 ppp [wan] IPCP: state change Opened --> Closing Dec 3 20:39:05 ppp [wan] IPCP: SendTerminateReq #4 Dec 3 20:39:05 ppp [wan] IPCP: LayerDown Dec 3 20:39:05 ppp [wan] IPV6CP: Close event Dec 3 20:39:05 ppp [wan] IPV6CP: state change Opened --> Closing Dec 3 20:39:05 ppp [wan] IPV6CP: SendTerminateReq #2 Dec 3 20:39:05 ppp [wan] IPV6CP: LayerDown Dec 3 20:39:05 ppp [wan] IFACE: Down event Dec 3 20:39:05 ppp [wan] IFACE: Rename interface pppoe2 to pppoe2 Dec 3 20:39:05 ppp [wan] IPCP: rec'd Terminate Ack #4 (Closing) Dec 3 20:39:05 ppp [wan] IPCP: state change Closing --> Closed Dec 3 20:39:05 ppp [wan] IPCP: LayerFinish Dec 3 20:39:05 ppp [wan_link0] LCP: rec'd Terminate Request #117 (Opened) Dec 3 20:39:05 ppp [wan_link0] LCP: state change Opened --> Stopping Dec 3 20:39:05 ppp [wan_link0] Link: Leave bundle "wan" Dec 3 20:39:05 ppp [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps Dec 3 20:39:05 ppp [wan] IPCP: Close event Dec 3 20:39:05 ppp [wan] IPV6CP: Close event Dec 3 20:39:05 ppp [wan] IPCP: Down event Dec 3 20:39:05 ppp [wan] IPCP: state change Closed --> Initial Dec 3 20:39:05 ppp [wan] IPV6CP: Down event Dec 3 20:39:05 ppp [wan] IPV6CP: LayerFinish Dec 3 20:39:05 ppp [wan] Bundle: No NCPs left. Closing links... Dec 3 20:39:05 ppp [wan] IPV6CP: state change Closing --> Initial Dec 3 20:39:05 ppp [wan_link0] LCP: SendTerminateAck #3 Dec 3 20:39:05 ppp [wan_link0] LCP: LayerDown Dec 3 20:39:05 ppp [wan] rec'd unexpected protocol IP Dec 3 20:39:05 ppp [wan] rec'd unexpected protocol IP Dec 3 20:39:05 ppp [wan_link0] PPPoE: connection closed Dec 3 20:39:05 ppp [wan_link0] Link: DOWN event Dec 3 20:39:05 ppp [wan_link0] Link: giving up after 0 reconnection attempts Dec 3 20:39:05 ppp [wan_link0] LCP: Close event Dec 3 20:39:05 ppp [wan_link0] LCP: state change Stopping --> Closing Dec 3 20:39:05 ppp [wan_link0] LCP: Down event Dec 3 20:39:05 ppp [wan_link0] LCP: LayerFinish Dec 3 20:39:05 ppp [wan_link0] LCP: state change Closing --> Initial Dec 3 20:39:06 ppp waiting for process 70115 to die... Dec 3 20:39:07 ppp waiting for process 70115 to die... Dec 3 20:39:07 ppp [wan] Bundle: Shutdown Dec 3 20:39:07 ppp [wan_link0] Link: Shutdown Dec 3 20:39:07 ppp process 70115 terminated Dec 3 20:39:08 ppp web: web is not running Dec 3 20:39:08 ppp [wan] Bundle: Interface ng0 created Dec 3 20:39:08 ppp [wan_link0] Link: OPEN event Dec 3 20:39:08 ppp [wan_link0] LCP: Open event Dec 3 20:39:08 ppp [wan_link0] LCP: state change Initial --> Starting Dec 3 20:39:08 ppp [wan_link0] LCP: LayerStart Dec 3 20:39:08 ppp [wan_link0] PPPoE: Connecting to '' Dec 3 20:39:08 ppp PPPoE: rec'd ACNAME "acc-aln2.lv-wal" Dec 3 20:39:08 ppp [wan_link0] PPPoE: connection successful Dec 3 20:39:08 ppp [wan_link0] Link: UP event Dec 3 20:39:08 ppp [wan_link0] LCP: Up event Dec 3 20:39:08 ppp [wan_link0] LCP: state change Starting --> Req-Sent Dec 3 20:39:08 ppp [wan_link0] LCP: SendConfigReq #1 Dec 3 20:39:08 ppp [wan_link0] PROTOCOMP Dec 3 20:39:08 ppp [wan_link0] MRU 1492 Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0xbe79b0b4 Dec 3 20:39:08 ppp [wan_link0] LCP: rec'd Configure Request #13 (Req-Sent) Dec 3 20:39:08 ppp [wan_link0] MRU 1492 Dec 3 20:39:08 ppp [wan_link0] AUTHPROTO CHAP MD5 Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0x40bd5d5d Dec 3 20:39:08 ppp [wan_link0] LCP: SendConfigAck #13 Dec 3 20:39:08 ppp [wan_link0] MRU 1492 Dec 3 20:39:08 ppp [wan_link0] AUTHPROTO CHAP MD5 Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0x40bd5d5d Dec 3 20:39:08 ppp [wan_link0] LCP: state change Req-Sent --> Ack-Sent Dec 3 20:39:08 ppp [wan_link0] LCP: rec'd Configure Reject #1 (Ack-Sent) Dec 3 20:39:08 ppp [wan_link0] PROTOCOMP Dec 3 20:39:08 ppp [wan_link0] LCP: SendConfigReq #2 Dec 3 20:39:08 ppp [wan_link0] MRU 1492 Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0xbe79b0b4 Dec 3 20:39:08 ppp [wan_link0] rec'd proto CHAP during establishment phase Dec 3 20:39:08 ppp [wan_link0] LCP: rec'd Configure Ack #2 (Ack-Sent) Dec 3 20:39:08 ppp [wan_link0] MRU 1492 Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0xbe79b0b4 Dec 3 20:39:08 ppp [wan_link0] LCP: state change Ack-Sent --> Opened Dec 3 20:39:08 ppp [wan_link0] LCP: auth: peer wants CHAP, I want nothing Dec 3 20:39:08 ppp [wan_link0] LCP: LayerUp Dec 3 20:39:11 ppp [wan_link0] CHAP: rec'd CHALLENGE #1 len: 69 Dec 3 20:39:11 ppp [wan_link0] Name: "acc-aln2.lv-wal" Dec 3 20:39:11 ppp [wan_link0] CHAP: Using authname "bthomehub@btinternet.com" Dec 3 20:39:11 ppp [wan_link0] CHAP: sending RESPONSE #1 len: 45 Dec 3 20:39:11 ppp [wan_link0] CHAP: rec'd SUCCESS #1 len: 31 Dec 3 20:39:11 ppp [wan_link0] MESG: CHAP authentication success Dec 3 20:39:11 ppp [wan_link0] LCP: authorization successful Dec 3 20:39:11 ppp [wan_link0] Link: Matched action 'bundle "wan" ""' Dec 3 20:39:11 ppp [wan_link0] Link: Join bundle "wan" Dec 3 20:39:11 ppp [wan] Bundle: Status update: up 1 link, total bandwidth 64000 bps Dec 3 20:39:11 ppp [wan] IPCP: Open event Dec 3 20:39:11 ppp [wan] IPCP: state change Initial --> Starting Dec 3 20:39:11 ppp [wan] IPCP: LayerStart Dec 3 20:39:11 ppp [wan] IPV6CP: Open event Dec 3 20:39:11 ppp [wan] IPV6CP: state change Initial --> Starting Dec 3 20:39:11 ppp [wan] IPV6CP: LayerStart Dec 3 20:39:11 ppp [wan] IPCP: Up event Dec 3 20:39:11 ppp [wan] IPCP: state change Starting --> Req-Sent Dec 3 20:39:11 ppp [wan] IPCP: SendConfigReq #1 Dec 3 20:39:11 ppp [wan] IPADDR 0.0.0.0 Dec 3 20:39:11 ppp [wan] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Dec 3 20:39:11 ppp [wan] IPV6CP: Up event Dec 3 20:39:11 ppp [wan] IPV6CP: state change Starting --> Req-Sent Dec 3 20:39:11 ppp [wan] IPV6CP: SendConfigReq #1 Dec 3 20:39:11 ppp [wan] IPV6CP: rec'd Configure Request #146 (Req-Sent) Dec 3 20:39:11 ppp [wan] IPV6CP: SendConfigAck #146 Dec 3 20:39:11 ppp [wan] IPV6CP: state change Req-Sent --> Ack-Sent Dec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Request #49 (Req-Sent) Dec 3 20:39:11 ppp [wan] IPADDR 172.16.13.94 Dec 3 20:39:11 ppp [wan] 172.16.13.94 is OK Dec 3 20:39:11 ppp [wan] IPCP: SendConfigAck #49 Dec 3 20:39:11 ppp [wan] IPADDR 172.16.13.94 Dec 3 20:39:11 ppp [wan] IPCP: state change Req-Sent --> Ack-Sent Dec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Reject #1 (Ack-Sent) Dec 3 20:39:11 ppp [wan] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid Dec 3 20:39:11 ppp [wan] IPCP: SendConfigReq #2 Dec 3 20:39:11 ppp [wan] IPADDR 0.0.0.0 Dec 3 20:39:11 ppp [wan] IPV6CP: rec'd Configure Ack #1 (Ack-Sent) Dec 3 20:39:11 ppp [wan] IPV6CP: state change Ack-Sent --> Opened Dec 3 20:39:11 ppp [wan] IPV6CP: LayerUp Dec 3 20:39:11 ppp [wan] 0215:5dff:fe00:0102 -> 22e0:9cff:fe16:c801 Dec 3 20:39:11 ppp [wan] IFACE: Up event Dec 3 20:39:11 ppp [wan] IFACE: Rename interface ng0 to pppoe2 Dec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Nak #2 (Ack-Sent) Dec 3 20:39:11 ppp [wan] IPADDR 86.178.28.70 Dec 3 20:39:11 ppp [wan] 86.178.28.70 is OK Dec 3 20:39:11 ppp [wan] IPCP: SendConfigReq #3 Dec 3 20:39:11 ppp [wan] IPADDR 86.178.28.70 Dec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Ack #3 (Ack-Sent) Dec 3 20:39:11 ppp [wan] IPADDR 86.178.28.70 Dec 3 20:39:11 ppp [wan] IPCP: state change Ack-Sent --> Opened Dec 3 20:39:11 ppp [wan] IPCP: LayerUp Dec 3 20:39:11 ppp [wan] 86.178.28.70 -> 172.16.13.94
Dec 3 20:39:05 ppp Multi-link PPP daemon for FreeBSDDec 3 20:39:05 ppp process 22871 started, version 5.8 (root@pfSense_v2_4_4_amd64-pfSense_v2_4_4-job-09 11:56 16-Nov-2018)Dec 3 20:39:05 ppp waiting for process 70115 to die...Dec 3 20:39:05 ppp caught fatal signal TERMDec 3 20:39:05 ppp [wan] IFACE: Close eventDec 3 20:39:05 ppp [wan] IPCP: Close eventDec 3 20:39:05 ppp [wan] IPCP: state change Opened --> ClosingDec 3 20:39:05 ppp [wan] IPCP: SendTerminateReq #4Dec 3 20:39:05 ppp [wan] IPCP: LayerDownDec 3 20:39:05 ppp [wan] IPV6CP: Close eventDec 3 20:39:05 ppp [wan] IPV6CP: state change Opened --> ClosingDec 3 20:39:05 ppp [wan] IPV6CP: SendTerminateReq #2Dec 3 20:39:05 ppp [wan] IPV6CP: LayerDownDec 3 20:39:05 ppp [wan] IFACE: Down eventDec 3 20:39:05 ppp [wan] IFACE: Rename interface pppoe2 to pppoe2Dec 3 20:39:05 ppp [wan] IPCP: rec'd Terminate Ack #4 (Closing)Dec 3 20:39:05 ppp [wan] IPCP: state change Closing --> ClosedDec 3 20:39:05 ppp [wan] IPCP: LayerFinishDec 3 20:39:05 ppp [wan_link0] LCP: rec'd Terminate Request #117 (Opened)Dec 3 20:39:05 ppp [wan_link0] LCP: state change Opened --> StoppingDec 3 20:39:05 ppp [wan_link0] Link: Leave bundle "wan"Dec 3 20:39:05 ppp [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bpsDec 3 20:39:05 ppp [wan] IPCP: Close eventDec 3 20:39:05 ppp [wan] IPV6CP: Close eventDec 3 20:39:05 ppp [wan] IPCP: Down eventDec 3 20:39:05 ppp [wan] IPCP: state change Closed --> InitialDec 3 20:39:05 ppp [wan] IPV6CP: Down eventDec 3 20:39:05 ppp [wan] IPV6CP: LayerFinishDec 3 20:39:05 ppp [wan] Bundle: No NCPs left. Closing links...Dec 3 20:39:05 ppp [wan] IPV6CP: state change Closing --> InitialDec 3 20:39:05 ppp [wan_link0] LCP: SendTerminateAck #3Dec 3 20:39:05 ppp [wan_link0] LCP: LayerDownDec 3 20:39:05 ppp [wan] rec'd unexpected protocol IPDec 3 20:39:05 ppp [wan] rec'd unexpected protocol IPDec 3 20:39:05 ppp [wan_link0] PPPoE: connection closedDec 3 20:39:05 ppp [wan_link0] Link: DOWN eventDec 3 20:39:05 ppp [wan_link0] Link: giving up after 0 reconnection attemptsDec 3 20:39:05 ppp [wan_link0] LCP: Close eventDec 3 20:39:05 ppp [wan_link0] LCP: state change Stopping --> ClosingDec 3 20:39:05 ppp [wan_link0] LCP: Down eventDec 3 20:39:05 ppp [wan_link0] LCP: LayerFinishDec 3 20:39:05 ppp [wan_link0] LCP: state change Closing --> InitialDec 3 20:39:06 ppp waiting for process 70115 to die...Dec 3 20:39:07 ppp waiting for process 70115 to die...Dec 3 20:39:07 ppp [wan] Bundle: ShutdownDec 3 20:39:07 ppp [wan_link0] Link: ShutdownDec 3 20:39:07 ppp process 70115 terminatedDec 3 20:39:08 ppp web: web is not runningDec 3 20:39:08 ppp [wan] Bundle: Interface ng0 createdDec 3 20:39:08 ppp [wan_link0] Link: OPEN eventDec 3 20:39:08 ppp [wan_link0] LCP: Open eventDec 3 20:39:08 ppp [wan_link0] LCP: state change Initial --> StartingDec 3 20:39:08 ppp [wan_link0] LCP: LayerStartDec 3 20:39:08 ppp [wan_link0] PPPoE: Connecting to ''Dec 3 20:39:08 ppp PPPoE: rec'd ACNAME "acc-aln2.lv-wal"Dec 3 20:39:08 ppp [wan_link0] PPPoE: connection successfulDec 3 20:39:08 ppp [wan_link0] Link: UP eventDec 3 20:39:08 ppp [wan_link0] LCP: Up eventDec 3 20:39:08 ppp [wan_link0] LCP: state change Starting --> Req-SentDec 3 20:39:08 ppp [wan_link0] LCP: SendConfigReq #1Dec 3 20:39:08 ppp [wan_link0] PROTOCOMPDec 3 20:39:08 ppp [wan_link0] MRU 1492Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0xbe79b0b4Dec 3 20:39:08 ppp [wan_link0] LCP: rec'd Configure Request #13 (Req-Sent)Dec 3 20:39:08 ppp [wan_link0] MRU 1492Dec 3 20:39:08 ppp [wan_link0] AUTHPROTO CHAP MD5Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0x40bd5d5dDec 3 20:39:08 ppp [wan_link0] LCP: SendConfigAck #13Dec 3 20:39:08 ppp [wan_link0] MRU 1492Dec 3 20:39:08 ppp [wan_link0] AUTHPROTO CHAP MD5Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0x40bd5d5dDec 3 20:39:08 ppp [wan_link0] LCP: state change Req-Sent --> Ack-SentDec 3 20:39:08 ppp [wan_link0] LCP: rec'd Configure Reject #1 (Ack-Sent)Dec 3 20:39:08 ppp [wan_link0] PROTOCOMPDec 3 20:39:08 ppp [wan_link0] LCP: SendConfigReq #2Dec 3 20:39:08 ppp [wan_link0] MRU 1492Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0xbe79b0b4Dec 3 20:39:08 ppp [wan_link0] rec'd proto CHAP during establishment phaseDec 3 20:39:08 ppp [wan_link0] LCP: rec'd Configure Ack #2 (Ack-Sent)Dec 3 20:39:08 ppp [wan_link0] MRU 1492Dec 3 20:39:08 ppp [wan_link0] MAGICNUM 0xbe79b0b4Dec 3 20:39:08 ppp [wan_link0] LCP: state change Ack-Sent --> OpenedDec 3 20:39:08 ppp [wan_link0] LCP: auth: peer wants CHAP, I want nothingDec 3 20:39:08 ppp [wan_link0] LCP: LayerUpDec 3 20:39:11 ppp [wan_link0] CHAP: rec'd CHALLENGE #1 len: 69Dec 3 20:39:11 ppp [wan_link0] Name: "acc-aln2.lv-wal"Dec 3 20:39:11 ppp [wan_link0] CHAP: Using authname "bthomehub@btinternet.com"Dec 3 20:39:11 ppp [wan_link0] CHAP: sending RESPONSE #1 len: 45Dec 3 20:39:11 ppp [wan_link0] CHAP: rec'd SUCCESS #1 len: 31Dec 3 20:39:11 ppp [wan_link0] MESG: CHAP authentication successDec 3 20:39:11 ppp [wan_link0] LCP: authorization successfulDec 3 20:39:11 ppp [wan_link0] Link: Matched action 'bundle "wan" ""'Dec 3 20:39:11 ppp [wan_link0] Link: Join bundle "wan"Dec 3 20:39:11 ppp [wan] Bundle: Status update: up 1 link, total bandwidth 64000 bpsDec 3 20:39:11 ppp [wan] IPCP: Open eventDec 3 20:39:11 ppp [wan] IPCP: state change Initial --> StartingDec 3 20:39:11 ppp [wan] IPCP: LayerStartDec 3 20:39:11 ppp [wan] IPV6CP: Open eventDec 3 20:39:11 ppp [wan] IPV6CP: state change Initial --> StartingDec 3 20:39:11 ppp [wan] IPV6CP: LayerStartDec 3 20:39:11 ppp [wan] IPCP: Up eventDec 3 20:39:11 ppp [wan] IPCP: state change Starting --> Req-SentDec 3 20:39:11 ppp [wan] IPCP: SendConfigReq #1Dec 3 20:39:11 ppp [wan] IPADDR 0.0.0.0Dec 3 20:39:11 ppp [wan] COMPPROTO VJCOMP, 16 comp. channels, no comp-cidDec 3 20:39:11 ppp [wan] IPV6CP: Up eventDec 3 20:39:11 ppp [wan] IPV6CP: state change Starting --> Req-SentDec 3 20:39:11 ppp [wan] IPV6CP: SendConfigReq #1Dec 3 20:39:11 ppp [wan] IPV6CP: rec'd Configure Request #146 (Req-Sent)Dec 3 20:39:11 ppp [wan] IPV6CP: SendConfigAck #146Dec 3 20:39:11 ppp [wan] IPV6CP: state change Req-Sent --> Ack-SentDec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Request #49 (Req-Sent)Dec 3 20:39:11 ppp [wan] IPADDR 172.16.13.94Dec 3 20:39:11 ppp [wan] 172.16.13.94 is OKDec 3 20:39:11 ppp [wan] IPCP: SendConfigAck #49Dec 3 20:39:11 ppp [wan] IPADDR 172.16.13.94Dec 3 20:39:11 ppp [wan] IPCP: state change Req-Sent --> Ack-SentDec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Reject #1 (Ack-Sent)Dec 3 20:39:11 ppp [wan] COMPPROTO VJCOMP, 16 comp. channels, no comp-cidDec 3 20:39:11 ppp [wan] IPCP: SendConfigReq #2Dec 3 20:39:11 ppp [wan] IPADDR 0.0.0.0Dec 3 20:39:11 ppp [wan] IPV6CP: rec'd Configure Ack #1 (Ack-Sent)Dec 3 20:39:11 ppp [wan] IPV6CP: state change Ack-Sent --> OpenedDec 3 20:39:11 ppp [wan] IPV6CP: LayerUpDec 3 20:39:11 ppp [wan] 0215:5dff:fe00:0102 -> 22e0:9cff:fe16:c801Dec 3 20:39:11 ppp [wan] IFACE: Up eventDec 3 20:39:11 ppp [wan] IFACE: Rename interface ng0 to pppoe2Dec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Nak #2 (Ack-Sent)Dec 3 20:39:11 ppp [wan] IPADDR 86.178.28.70Dec 3 20:39:11 ppp [wan] 86.178.28.70 is OKDec 3 20:39:11 ppp [wan] IPCP: SendConfigReq #3Dec 3 20:39:11 ppp [wan] IPADDR 86.178.28.70Dec 3 20:39:11 ppp [wan] IPCP: rec'd Configure Ack #3 (Ack-Sent)Dec 3 20:39:11 ppp [wan] IPADDR 86.178.28.70Dec 3 20:39:11 ppp [wan] IPCP: state change Ack-Sent --> OpenedDec 3 20:39:11 ppp [wan] IPCP: LayerUpDec 3 20:39:11 ppp [wan] 86.178.28.70 -> 172.16.13.94
Any help you can give is greatly appreciated.
