cameronjor
Newbie
Message 1 of 17
Problems with internet speed
I live out in the middle of no where so I accept my poor internet connection, but recently like a 3 months ago my internet speed has got poorer. Before, when I was downloading things on my laptop it would download at around 75 kbs but now It downloads at 20 kbs and this is a big differnce in terms of speeds I get as it has now made playing xbox live impossible where before it was possible to play online. My mother called up and they suggested a new hub, BT Home Hub 3, but this has not made any diffence.
Speed Test
16 REPLIES 16
Message 2 of 17
Re: Problems with internet speed
Welcome to this customer to customer forum.
To enable forum members to help you, please could you look at Helping forum members to help you which asks you to do a few checks first, and has some helpful hints.
When you have done that, please post the results here, so members can offer advice. Thank you.
cameronjor123
Message 3 of 17
I had to make a new account as for some reason my email was not recognised by BT even though I have an email from them. Anyway as requested here are my ADSL stats
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):10.2 dB / 5.0 dB
Line attenuation (Down/Up):57.6 dB / 31.5 dB
Output power (Down/Up):16.9 dBm / 12.4 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):4957 / 0
dcwt2010
Message 4 of 17
Hey Cameron, you need to post the connection time and sync rate Down/Up.
Based on that attenuation figure you should get a 3Mbs downstream connection if it was perfect line. I can see there's quite a few errors on the line but we need to the system up time to see how regular they actually are.
cameronjor123
Message 5 of 17
Thanks for your quick reply, is this what you need?
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:45:43
Downstream:576 Kbps
Upstream:128 Kbps
dcwt2010
Message 6 of 17
Yup. That upstream is speed is very low, most lines can maintain 448Kbs. Anyway, connection time of 45 minutes, did you manually restart the router or you haven't touched it? If it's the former then your router is having trouble maintaining a connection. An unstable line means that you're stuck with a trickle.
There's a lot of troubleshooting we need to cover. First of all, can you connect to the test socket? Next, how many phone points do you have in the house?
Message 7 of 17
hi are you connected to the test socket
cameronjor123
Message 8 of 17
My broadband always goes down so I restarted it so I could check this, it's a new router as well. Once I connect to the test socket do I post my ASDL stats again? And I will count my phone points.
Message 9 of 17
yes please post your hub stats again once connected to the test socket
cameronjor123
Message 10 of 17
ADSL Line Status
Connection time:0 days, 00:03:06
Downstream:576 Kbps
Upstream:64 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):8.4 dB / 5.0 dB
Line attenuation (Down/Up):59.5 dB / 31.5 dB
Output power (Down/Up):16.6 dBm / 12.2 dBm
FEC Events (Down/Up):0 / 5
CRC Events (Down/Up):607 / 4
