john46
Message 11 of 29
Re: Problems with speeds
hi those are not your hub stats we are looking for noise margin attenuation and the error messages
groovychris
Message 12 of 29
DSL Connection
Link Information
Uptime: 0 days, 5:28:34
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,080
Data Transferred (Sent/Received) [MB/MB]: 43.42 / 793.60
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 58.0
SN Margin (Up/Down) [dB]: 18.0 / 5.5
Vendor ID (Local/Remote): TMMB / IFTN
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 7,595,992
CRC Errors (Up/Down): 0 / 57,868
HEC Errors (Up/Down): 0 / 31,535
Line Profile: Interleaved
imjolly
Message 13 of 29
from the stats you have a 2mb connection and noise margin normal but a lot of crc/hec errors for only 5hrs connected
are you connected to the test or master socket?  other sockets in your home?
did you try the quiet line test?
with your attenuation and a good line I would hope for about 3mb connection speed
groovychris
Message 14 of 29
I tried the quiet line test and it was successful.
I believe I'm connected to the master socket.
imjolly
Message 15 of 29
have you tried the test socket especially if you have other sockets
groovychris
Message 16 of 29
Going back to download speeds vs file transfer rates - if you've got BT Infinity 100MB (for example), what would a normal file transfer speed be?
imjolly
Message 17 of 29
did you read the like I posted before?  100mb connection speed give profile about 88mb with a download about 80 or maybe slightly higher with file transfer 10/12mb but will depend on where you are downloading from
john46 with his great connection may be more accurate as these high speeds a making me dizzySmiley Happy
john46
Message 18 of 29
an absolute max of around 12mb
groovychris
Message 19 of 29
I've just got the one phone socket in my house. We've got a line which runs up the stairs and through the hallway to an upstairs room where the router is kept (next to the desktop).
john46
Message 20 of 29
but you would only get a infinity 100mb connection with fibre to home not fibre to cabinet which is limited to 80 normally 76mb max
