imjolly
Message 21 of 29
Re: Problems with speeds
is that a phone extension cable or hub downstairs and running an ethernet cable upstairs to pc?
john46
Message 22 of 29
sounds like the hub is on an extension of some form
groovychris
Message 23 of 29
It's an extension cable.
imjolly
Message 24 of 29
is it possible to conenct hub to test socket instead of via extension cable ?
john46
Message 25 of 29
as extension cables especially the flat ones and those on reels are bad news for broadband use as they are known sources of interference
groovychris
Message 26 of 29
"is it possible to conenct hub to test socket instead of via extension cable?"
The problem is that the desktop upstairs is quite old and doesn't have built-in wifi capabilities.
If in theory I bought a wifi adaptor for the upstairs computer, and connected the hub to the test socket - would I be likely to enjoy faster speeds?
imjolly
Message 27 of 29
it would be better if you had hub downstairs conencted to master and then ran ethernet cable instead of the extension cable and that connected to pc.  that would give better connection for hub while maintaining a cable connection for your pc.  cat 5e/6 ethernet cable is not expensive and can be bought from well known auction site
john46
Message 28 of 29
agreed that is by far the best option
imjolly
Message 29 of 29
if you get that set up then post back with the stats if you need more help - there is always someone around to help
