ScottElliott
Message 1 of 8
Profile caped at 283 kbps
Hi
Last week I had a number of disconects this was due to a falty filter which i have replaced with a spair one I had, the clear line test was good and the conection has been stable for over 4 days now but theres been no change in the profile I normaly get speeds over 6000kbps.
Could my profile be manually reset?
Scott
 Download speedachieved during the test was - 0.25 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
DSL Link Up: Down Rate=283Kbps, Up Rate=1030Kbps; SNR Margin Down=13.5dB, Up=6.7dB
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: Profile caped at 283 kbps
Welcome to this user forum.
Its an automatic process, see https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/How-to-speed-up-return-to-normal-ADSL-speeds...
A manual reset woul only be done if the connection was still low after about 10 days.
Just leave it all alone, and it will recover.
ScottElliott
Message 3 of 8
So after 9+ days of connection I lost droped conection today not sure why but there has be no change to my profile can this please be looked into
15:13:53, 29 Jan.DSL Link Up: Down Rate=283Kbps, Up Rate=1184Kbps; SNR Margin Down=14.6dB, Up=6.2dB
15:13:47, 29 Jan.Tunnel is down
15:13:40, 29 Jan.WAN connection ATM disconnected
15:13:32, 29 Jan.PPP LCP Send Termination Request (User request)
15:13:29, 29 Jan.PPP LCP Send Termination Request (User request)
15:13:28, 29 Jan.DSL Link Down: duration was 828329 seconds
john46
Message 4 of 8
I have asked a forum moderator to help you they will post their contact link here
PaddyB
Moderator
Moderator
Message 5 of 8
Hi @ScottElliott,
I'll be able to take a look at your connection and run a few checks on your line.
You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
ScottElliott
Message 6 of 8
Looks like the cap has been lifted thanks for all your help guys
08:48:23, 30 Jan.DSL Link Up: Down Rate=4876Kbps, Up Rate=1188Kbps; SNR Margin Down=15.1dB, Up=6.3dB
PaddyB
Moderator
Moderator
Message 7 of 8
Hi @ScottElliott,
Thank you for taking my call yesterday. I've tested your connection today and your sync speed has increased to 7143 Kbps. This has enabled a profile of 6093 Kbps.
I'll be back in touch at the end of the week to see how the connection is preforming.
PaddyB
PaddyB
Moderator
Moderator
Message 8 of 8
Hi @ScottElliott,
I gave your mobile a quick call, I'm sorry I didn't get speaking to you. I've tested your connection and its looking pretty good. The profile has increase to 6301 Kbps. The connection has been nice and stable with no drop outs over the last 3 days.
PaddyB
