Message 1 of 21
Property address classified as Silver
Hi there.
Going round in circles trying to get this issue resolved.
Just moved into a new build that was a show home/sales office. BT is installed there and has been used for the past four years by the developer. When calling BT to take over the service they says the property is "silver" status and can't help. I would need to contact Open Reach. OR have no contact numbers and can only be communicated with by online form (which I have done and they have said they will respond within 28 days). When checking their database, every house in the road appears except mine, although their technology is already the house.
Can anyone help?
20 REPLIES 20
Message 2 of 21
Re: Property address classified as Silver
if a new build do you have an ONT for FTTP
how do you know the previous provider was BT retail and not another ISP as they also used the openreach network?
Message 3 of 21
@ChrisDavies
You would need to follow the process for ordering a new phone line first. Once that has been provided, then the Openreach database will be updated and you will be able to see what broadband options are available to you.
Place an order for a line only using this link - https://www.bt.com/landline/deals
If the address doesn't appear properly when you enter the postcode, there is a section underneath where you can manually enter the address.  This will raise the order with the address showing as bronze and it will prompt Openreach to carry out a survey to confirm the routing.   Once the routing is updated the order will then progress as normal.  You can then add broadband once you have the line up and running.
Message 4 of 21
Hi there. I will need to ask the question as I now have a tenant in place who is desperate to get broadband up and running. Will contact now and update this post. Thanks
Message 5 of 21
Hi there. I just tried that process and when it came to adding my postcode the house number didn't appear in the main list but at the very bottom. The response back was that they would check what services were available at that address and get back to me within 28 days. I think it may have something to do with my address not appearing in the Open Reach database possibly.
Message 6 of 21
Regarding your question about the existing ISP, this is what I was told by the developer, Barratt's.
Message 7 of 21
many people use the 'BT' when they actually mean openreach hence why check to see which ISP previously had the connection.  if been show house then there would have been an active line
Message 8 of 21
Is there anyway of finding this out online as the developer hasn't been very helpful.
Message 9 of 21
Just been in contact with the developer who stated that there have never been any services registered at the address. They just say every new build has the technology in place from Open Reach for new owners to order services.
Message 10 of 21
@ChrisDavies
Then that is what you will need to do, place an order.
That will update the Openreach database with the routing.
Openreach will not do anything without an order.
