Message 1 of 5
Public ip / default gateway
Hi community
Really quick question regarding my public ip address and *public* default gateway.
They are completely different, is this normal on a FTTC connection?
Example:
Public ip: 17.168.192.47
Default gateway: 62.211.18.3
Thanks in advance
4 REPLIES 4
Message 2 of 5
Re: Public ip / default gateway
What do you mean by *public* default gateway?
Public IP is provided by your ISP. The default gateway is you hub/router address.
Message 3 of 5
Hi, thanks for the reply.
If you log in to your router. I have the smart hub 2.
Click advanced, broadband, then under the Internet section right at the bottom.
It has tcp/ip information.
It has my public ip address : 5.80.***.***
Default gateway: 172.16.***.***
I thought default gateway would be : 192.168.1.254
Message 4 of 5
192.168.1.254 is the default gateway for your devices I.e the hub. The 172.16 address is the default gateway for your router and is the address of the BT BRAS.
Message 5 of 5
Thanks for your help 👍
