DavidM
Moderator
Moderator
Message 11 of 13
Re: Pure Prepaid Visa Card
Hi @sjms01,
Thanks for posting. This is a little differrent than chasing up a lost or delayed delivery card as you've already received one. can I ask what the problem is with the original card? Did you try to use it?
Cheers
David
sjms01
Message 12 of 13
Hi David,
Thank you for the reply.
No I didnt get to use the card, I tried to check the balance online and received a message the action wasnt authorised and the card had been loclked. I contacted Pure, I was told the card had been cancelled as it hadnt been rregistered which isnt correct.
I was told to contact BT and they would issue another card. I received confirmation the card was processed manually on 2nd Feb and should be with me within 15days. Todate I havent received the card, the email correspondance is rather inconsistentn and I really dont have confidence with what I am being advised. I can forward the email chain if that helps.
Regards
Steve
DavidM
Moderator
Moderator
Message 13 of 13
Thanks for confirming that @sjms01. Can you send over the details and I'll chase this up for you. You'll get the contact the moderators link in my profile. We're busier than usual at present so it'll take a little longer getting back to you but as soon as we pick up the case we'll be in touch.
Cheers
David
