lee87
Message 1 of 5
Q about new laptop
when you get a new laptop do you have to put that disc in that you got when you first set up your hub?
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: Q about new laptop
Hi
I suggest you use the disc as a beer mat.
Not really needed.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 5
I agree with Dave, the software causes problems and can upset the wireless configuration on your laptop.
Message 4 of 5
or use the disc as a bird scarer
IanC
Recognised Expert
Message 5 of 5
My newest laptop (a netbook, actually) doesn't have a CD drive. It works just fine though...
