Message 11 of 17
Re: Question about testing period
@jkr1711 wrote:
Hi,
Test socket yields same results, and the bellwire got removed a few months ago. We have a phone upstairs using a different socket (not a phone extension cable) if that's anything.
Have you seen whether the CRC events increment when you are connected to the test socket?
I really think the issue is simply the lack of forward error correction, which is introduced then the latency id changed to interleaved.
This should eliminate most of the CRC errors.
Message 12 of 17
Hi,
It appears we are using an extension for the router as all of our PC's are wired into the homehub. It's not possible to test anything if we put it into the test socket as it is elsewhere in the house where the ethernet cables can't reach. I guess I'll just have to wait until the testing period is over (we've used other routers on the extension before and they've been running perfectly fine)
Regards
John
Message 13 of 17
I think its going to a case of wait and see. No manual intervention is allowed to take place until after the 10 days, and its important to leave your home hub plugged in and turned on 24/7 during this critical period, as that is when the fault threshold is calculated.
You are welcome to return to this thread and report the situation after 10 days, someone will be looking out for you Smiley Wink
Message 14 of 17
Broadband rebooted itself and now we're on Interleaved 😄 Speed down to 2.84mbps but I guess it's better than nothing
Regards
John
Message 15 of 17
has your noise margin increased above 6db?  as on interleaved that should significantly reduce the crc/hec errors which should improve your download speed
Message 16 of 17
Yes it has improved the margins, we are now on 7.4Dbs. Bring on Infinity! (If my cabinet ever gets seen to...)
Message 17 of 17
could you now repost a new set of hub stats now you are on interleaving
