Message 1 of 2
Questions?
1. When you connect to BT FON say by a Laptop or iPad, doesn't it slow down the the BT members broadband that we get BT FON from? 2. I have Xbox LIVE and it's saying I have a moderate NAT now you should have an Open NAT for the best possible results I have had this problem before and I fixed it by simply restarting the BT Home but with the BT Home Hub 3.0 it does not seem to change when I restart it does anyone know how to do this? Many Thanks Luke. C
1 REPLY 1
Message 2 of 2
Re: Questions?
1. No, regular broadband usage gets priority (with Infinity it's a non issue really with the speeds available)
2. Don't think you can change the NAT on the hub 3.
