TheBigJm
Message 1 of 6
ROUTER STATS
hi
About 3 months ago i was getting a lot of disconnections,i did a bit of research and i removed the bell wire and fitted a new faceplate to the master socket
The line is now very stable and i rarely get any disconnections
however i was getting wi fi dropouts from my laptop and i discovered the home hub was not set to the b/g/n setting only the b/g
I have now changed it to the b/g/n setting and the wi fi is rock solid
I re set the router about 3 days ago and i notice in the stats the noise margin is usually 2.6
tonight it is 3.3
am i best leaving it at this level or getting it fixed at 6
the beta speet test is 13.78 at 8.20pm
ADSL line status
Connection information<script type="text/javascript"></script>
Line stateConnected
Connection time3 days, 2:44:44
Downstream13,840 Kbps
Upstream1,176 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.3 dB / 5.5 dB
Line attenuation (Down/Up)31.0 dB / 14.3 dB
Output power (Down/Up)0.0 dBm / 13.0 dBm
Loss of Framing (Local)0
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)76948870 / 4294967264
CRC Errors (Down/Up)480 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)4139
5 REPLIES 5
Message 2 of 6
Re: ROUTER STATS
just leave it as it is stable and BT are trialling a noise margin of 3db for lines on 21CN.  your connection looks good
Message 3 of 6
Re: ROUTER STATS
there is noting wrong with your noise margin it is being trialled on stable lines just leave everything as it is
TheBigJm
Message 4 of 6
Re: ROUTER STATS
Thanks guys for your replies
so does adsl2+ have a noise margin of approx 3 on a trial basis and for how long ?
will they keep it at 3 if line is stable
cheers
Message 5 of 6
Re: ROUTER STATS
I think it will become the norm for most people so as long as line stable and download speed not affected by high crc/hec errors then the 3db will stay
Distinguished Guru
Distinguished Guru
Message 6 of 6
Re: ROUTER STATS
It might reassure you to know that, following some minor drop-out problems, my snr eventually settled at 3dB. The hub was reset the other day (decorator in) but prior to that it had been up for over 2 months without a twitch.
