Hey,
I've been experiencing this problem for well over a month now...I've replaced everything it could possible be within my home including the router BT hub 3 to a BT hub 4.
The only thing I have noticed when changing the hub to the 4 was a lower ping when not experiencing the ping spikes... normally sitting at 40 / 45 now around 30.
I consider my internet to be "good" when it's at around 5mps and 35/ 45 ping
I've had at least 4 line resets over this period 3 before engineer visit and 1 after it.
I have had a BT engineer come out to my home but, it's not consistent it of course was working like a charm but confirmed it was anything in my house if there was a issue. It was raining heavily at the time of visit.
I'll post some ping tests here, its the same on wired or wireless:
Ping test:
PING google.co.uk (216.58.198.195): 56 data bytes
64 bytes from 216.58.198.195: icmp_seq=0 ttl=51 time=56.719 ms
64 bytes from 216.58.198.195: icmp_seq=1 ttl=51 time=83.230 ms
64 bytes from 216.58.198.195: icmp_seq=2 ttl=51 time=57.351 ms
64 bytes from 216.58.198.195: icmp_seq=3 ttl=51 time=86.391 ms
64 bytes from 216.58.198.195: icmp_seq=4 ttl=51 time=46.533 ms
64 bytes from 216.58.198.195: icmp_seq=5 ttl=51 time=81.049 ms
64 bytes from 216.58.198.195: icmp_seq=6 ttl=51 time=52.332 ms
64 bytes from 216.58.198.195: icmp_seq=7 ttl=51 time=84.932 ms
64 bytes from 216.58.198.195: icmp_seq=8 ttl=51 time=42.740 ms
64 bytes from 216.58.198.195: icmp_seq=9 ttl=51 time=83.411 ms
Trace route:
traceroute to www.google.co.uk (216.58.198.195), 64 hops max, 72 byte packets
1 bthomehub (192.168.1.254) 3.342 ms 2.587 ms 2.578 ms
2 217.47.108.186 (217.47.108.186) 15.035 ms 27.785 ms 15.761 ms
3 217.47.108.161 (217.47.108.161) 15.815 ms 16.542 ms 15.816 ms
4 213.1.69.98 (213.1.69.98) 42.973 ms 81.683 ms 78.573 ms
5 31.55.165.103 (31.55.165.103) 90.473 ms 90.918 ms 96.877 ms
6 31.55.165.191 (31.55.165.191) 95.636 ms 15.805 ms 15.635 ms
7 31.55.165.109 (31.55.165.109) 14.775 ms 15.138 ms 14.751 ms
8 109.159.250.186 (109.159.250.186) 26.598 ms 15.348 ms 13.976 ms
9 core2-te0-0-0-17.ealing.ukcore.bt.net (109.159.250.158) 24.239 ms 28.021 ms 24.181 ms
10 peer5-te0-0-0-11.telehouse.ukcore.bt.net (109.159.254.243) 21.671 ms 26.402 ms 34.740 ms
11 109.159.253.67 (109.159.253.67) 34.874 ms 22.436 ms 23.014 ms
12 216.239.56.227 (216.239.56.227) 23.655 ms 23.303 ms 22.280 ms
13 216.58.215.195 (216.58.215.195) 22.572 ms 23.528 ms 25.344 ms
14 lhr26s03-in-f3.1e100.net (216.58.198.195) 22.916 ms 22.805 ms 33.232 ms
As you can see, lots of different numbers and its driving me crazy, it can work perfectly some nights/days and be up and down like this at any given time.
Any help on this greatly appreciated.
Bump.
Please if anyone can advise?
