Message 1 of 5
Random ringing
Hi all,
My landline phone is a BT Decor 2500 and has been working fine for many years. Only in last week or so has the phone started ringing randomly at all hours of the day and night, I do a 1471 and the only callers are from family and friends at a different time and date. The ringing isn't ring, ring... ring, ring... it's a single continuous ring which lasts for 5 or so seconds.
I've checked the manual for and Troubleshooting offers no advice, online even less, so can anyone had this issue or anything like it ? If so, how did you solve it ?
Many thanks,
4 REPLIES 4
Message 2 of 5
Re: Random ringing
Overnight testing can cause a single burst of ringing, the tester accessing the line is interpreted by the phone instrument as a ringing signal ( also explains why it doesn’t have the usual cadence , ring ring, pause, ring ring ), a line fault can also cause phones to intermittently make a noise, dialling 1471 in both of these cases would simply report the last genuine incoming call, not these phantom rings....
Message 3 of 5
Re: Random ringing
Thanks for the reply, should I get in touch with my landline provider and explain what's going on then ? Thanks again.
Message 4 of 5
Re: Random ringing
@outRAGEis it could be a line fault but if your telephone service isn't provided by BT Retail, you'll need to contact your service provider
Message 5 of 5
Re: Random ringing
Thanks, I'll do this first thing tomorrow morning. Cheers again.
