trZtn
Message 1 of 10
Random timeout and now interleaver depth has sky rocketed.
Hey,
So my service has been all fine and the interleave depth reported by my router was 1.  It's been like this since I first moved into my flat and had BT ADSL installed around the 3rd of Feburary.  Ping/latency to UK locations has been great, averaging 9-10.
Suddenly today there was a random dropout and now the router is reporting interleaver depth at 96.  Big difference despite the connection being stable for over 2 months, full load/peak times and not.
I am roughly 150 meters from the main exchange in Peterborough and my line is exchange only.  I would like to get Infinity/fibre but alas I cannot due to having an exchange only line.
I would very much like to get this resolved and have it set back to 1.
Router stats as follows, fresh reboot of router so no info on errors.
Mode:ADSL_2plus
Traffic Type:ATM
Status:Up
Link Power State:L0
 DownstreamUpstream
Line Coding(Trellis):OnOn
SNR Margin (0.1 dB):3262
Attenuation (0.1 dB):11075
Output Power (0.1 dBm):0126
Attainable Rate (Kbps):246641292
 Path 0 Path 1
 DownstreamUpstreamDownstreamUpstream
Rate (Kbps):22666127600
MSGc (# of bytes in overhead channel message):594500
B (# of bytes in Mux Data Frame):2345500
M (# of Mux Data Frames in FEC Data Frame):1100
T (Mux Data Frames over sync bytes):3100
R (# of check bytes in FEC Data Frame):16000
S (ratio of FEC over PMD Data Frame length):0.33121.37840.00.0
L (# of bits in PMD Data Frame):606132500
D (interleaver depth):96100
Delay (msec):7.950.340.00.0
INP (DMT symbol):1.10.00.00.0
Super Frames:314672844000
Super Frame Errors:0000
RS Words:6135749147393700
RS Correctable Errors:24949000
RS Uncorrectable Errors:0000
HEC Errors:0000
OCD Errors:0000
LCD Errors:0000
Total Cells:27168817149009400
Data Cells:983103326200
Bit Errors:0000
Total ES:00
Total SES:00
Total UAS:3535
9 REPLIES 9
imjolly
Message 2 of 10
Re: Random timeout and now interleaver depth has sky rocketed.
The one thing missing from the stats is connection time - can you add please
Can you try quiet line test. Dial 17070 option 2. Should be quiet and best done with corded phone
trZtn
Message 3 of 10
Tried a line test, couldn't hear anything to indicate any noise.
New router stats, current uptime for this: 1 Day(s) 21:22:10
Mode:ADSL_2plus
Traffic Type:ATM
Status:Up
Link Power State:L0
 DownstreamUpstream
SNR Margin (0.1 dB):3361
 Path 0 Path 1
Super Frames:10114242913860600
Super Frame Errors:2100
RS Words:1972276904144726100
RS Correctable Errors:10313722000
RS Uncorrectable Errors:128000
HEC Errors:248100
OCD Errors:0000
LCD Errors:0000
Total Cells:14266399149069977400
Data Cells:3556418622382704800
Bit Errors:011300
Total ES:11
Total SES:00
Total UAS:3535
john46
Message 4 of 10
Once you can maintain 3days + stable connection then post back your router stats again and the forum mods should be able to help you change you to fastpath
trZtn
Message 5 of 10
Hey again, 3+days now.  Router stats as follows:
3Day(s) 05:17:42
Mode:ADSL_2plus
Traffic Type:ATM
Status:Up
Link Power State:L0
 DownstreamUpstream
 Path 0 Path 1
Super Frames:172305241556868600
RS Words:3359951922415872800
RS Correctable Errors:16180709000
HEC Errors:248100
OCD Errors:0000
LCD Errors:0000
Total Cells:199186783783595676500
Data Cells:7003093914452808800
Bit Errors:011300
Total ES:11
Total SES:00
Total UAS:3535
imjolly
Message 6 of 10
mods will post a contact us link and change you to fast
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 2/3 working days either by phone or email
PaddyB
Moderator
Moderator
Message 7 of 10
 Hi TrZtn,
I'll be able to take a look at your connection. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
trZtn
Message 8 of 10
Heya, any update? Sent you my details on 07/04/15. Reference: 150407-******
imjolly
Message 9 of 10
please delete your ref as this is public forum
mods will get back to you usually in 2/3 working days
DavidM
Moderator
Moderator
Message 10 of 10
Hi trZth,
I’m glad the fastpath order has completed as expected. If you have any other queries please post and we’ll be happy to help.
Cheers
David
