latexgusset
Message 1 of 11
Range check
Apologies if this is a daft question - but how can you check whether you're on Range A or B as shown on BT's DSL checker? Would the ip profile be the definitive descriptor for this? My estimates are that I should receive 79.9 download, but my ip profile is 65. Is there something wrong on my line?
10 REPLIES 10
latexgusset
Message 2 of 11
Re: Range check
Any advise on this greatly appreciated?
legitimise_sailing
Distinguished Expert
Message 3 of 11
Re: Range check
The way to tell is to look at your IP Profile and see which range it falls into, A or B.
To say thanks for a helpful answer, please click the white star
Aarong
Guru
Message 4 of 11
Re: Range check
What if your speed doesn't fall into these two ranges? Mine doesn't.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
sps1013
Message 5 of 11
Re: Range check
An answer I'm keen to hear too!
My estimate on bt website is lower than the DSL checker which is 22Mb lower than my actual and ip profile speeds.
Confused?
latexgusset
Message 6 of 11
Re: Range check
I've had a look at my profile (65) and it falls outside the ranges quoted for me.  Do I need to contact the helpdesks or get BT to look at my line?
gg30340
Message 7 of 11
Re: Range check
The dslchecker is an estimate of what your line might be able to achieve if everything was perfect. That means, as all estimates do, that some may get more and some may get less. It is not a promise of the speed you will get.
If you are getting 65Mbps I doubt that BT or Openreach would do anything to try and improve that but you could always ask.
Here is an explanation of what your IP profile is and why it's more important than an estimate.
http://bt.custhelp.com/app/answers/detail/a_id/9760/c/
legitimise_sailing
Message 8 of 11
Re: Range check
What are the ranges?
latexgusset
Message 9 of 11
Re: Range check
The download ranges quoted are:
Range A: 80 - 79.9
Range B: 80 - 70
legitimise_sailing
Message 10 of 11
Re: Range check
Oh yeah, your 5Mbps off.
