jessieros
Message 1 of 5
Re: BT 8500 Display Date
My 8500 shows the day in the calls register rather than the date. That's fine except it's the wrong day of the week, although the date I entered in the setup is correct! Any thoughts re that gratefully accepted
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
@jessieros can you follow the guidance on page 57 of the BT8500 userguide to make sure the date and year are both correct in the settings? Post back to let me know how you get on.
jessieros
Message 3 of 5
Hi Neil Thanks so much for your quick response and you are absolutely right. Day and month ok but was showing 2015! Not sure how that happened but now fine!
NeilO
Moderator
Moderator
Message 4 of 5
@jessieros No problem, thanks for letting me know it worked. I've moved your posts to its own thread as this might help others with the same problem and it will be easier for them to find. Smiley Happy
davidwf
Message 5 of 5
I had this too...and found the year was 2014 !!!....how can this happen - I thought the system clock was set from the CLI on an incoming call just before it rings....and we get enough calls to satisfy that criteria !
