Message 1 of 3
Re: BT Fon iPhone/iPad app update doesn't work - tells me wifi switched off
Been having this problem for a while now, is there a workaround or a cure nowadays?
2 REPLIES 2
Moderator-Retired
Message 2 of 3
Hi Bert0364
If you go into settings and connect to BT FON and then go back in through the FON app it should pick up the connection.
Bit round about but it should do the trick.
Thx
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
Newbie
Message 3 of 3
This solution doesn't work for me. I have reinstalled the app, have the latest software, have block pop-ups on, have= on, cleared history & cookies and hard reset the devices. Help.
