Message 1 of 4
Re: BT Infinity 2 installed but slow speeds
Infinity 2 Top Package installed Sept 9th.
Has dropped out 3 times, requiring re-boot.
Speed Test Results have been below 40 Mbps.
1. Best Effort Test:
Download Speed : 44.62 Mbps
2. Upstream Test:
Upload Speed : 11.9 Mbps
3 REPLIES 3
Message 2 of 4
The speed test you have posted is obviously above 40Mbps so I presume it was on another test it was below 40Mbps.
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
I assume you have a Homehub 5 so can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
Message 3 of 4
How long have you had it? Takes about 10 days for the speeds to settle.
Sage
Message 4 of 4
Since Sept 9th, just as it says in the OP.
