Message 1 of 2
Re: BT Infinity 2 installed but slow speeds
I have Infinity 2 and for me it seems slow, I was quoted my line was capble of 54Mbps when i ordered. Originally it was up close to that but it has slowed over time. Now the best I get is around 38.5Mbps down and 6.4 up. I've queried this with BT and they say because I am within 70% of the quoted speed they will not look at it 😞
Anyone know if this is correct?
My line speed is now showing as 39.4 so unless I can get this improved I'm stuck with it so really I should be paying for Infinity 1. I'm suspious though that if I change to Infinity 1 I will get an even slower throughput.
Tags (2)
1 REPLY 1
Message 2 of 2
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
