TVmad1998
Message 1 of 6
Re: BT Infinity 2 slow speeds during peak time
When BT put my Infinity 2 plus youview box in to my home they did a speed test and they got 68Mbps and told me that after some time about a week it should be stable and minium should the 68Mbps but it will be higher as I am only 100 yards from box and only less then 1/2 mile away from the BT exchange.
and week later i got 74Mbps then got a new laptop and it had USB 3 so I got a TP-Link dongle and then tested the speed and I got 84.4Mbps and this went on for a year not droping below 76Mbps ..
But a week ago I did a test and I saw speeds at 41Mbps and looked on BT site to see if there was any troubles and there was and it said phonlines so I gave it until today and all clear and did and test and got the same...
I now make sure that laptop was not the the trouble and got my other laptops and they all gave around the give and take 2Mbps  I looked in to the hub 5a settings and it is saying 45Mbps max ?
I did tests from 10pm to 5am to see if traffic is the trouble and no it was not.
So I phoned and been told that my line was OK which I was already knew as I did all the BT  site tests  but I told him all speeds I have had and that I should be 70Mbps if not higher   .... he then said he would reset my hub and it took a little time and he came back and said that it will take about 1/2 hour for speed to build up and hour to fix a speed .....
will at this time I getting 44.7Mbps which a little better BUT were has my 84.4 Mbps gone then BT ?????
I feel BT must be cutting speed for many over the UK as they have droped my speed slowly over time as I did not see the diffence until this week and not happy as I am getting service that I pay for.....
Is the BT network full with the increases of BT Sports extra 15 channels and others the on Youview boxes ?
5 REPLIES 5
imjolly
Message 2 of 6
can you post stats from your hub - go to hub manager then troubleshooting then helpdesk
can you run btspeedtester and when first test completes then run diagnostic test and post results  do not reset before test and test must be done with wired conenction
from your post it appears that it is your wireless devices that are ahving a problem so have you tried ethernet conenction to see if any better
pippincp
Sage
Message 3 of 6
Also enter your phone number HERE and post the result (remember to remove your phone number).
TVmad1998
Message 4 of 6
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ33802919
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 05/07/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 22:03:31
6. Data rate:19999 / 46901
7. Maximum data rate:22995 / 72392
8. Noise margin:14.6 / 12.4
9. Line attenuation:19.9 / 16.4
10. Signal attenuation:19.6 / 16.5
11. Data sent/received:328.2 MB / 4.1 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-296F 2
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-296F 5
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:62:2c:15:8d:78
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
john46
Message 5 of 6
your noise margin is very high suggesting a line fault
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
can you also try connecting to the test socket
TVmad1998
Message 6 of 6
Featured Products  Downstream Line Rate(Mbps) Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
                                           High             Low            High          Low
FTTC Range A (Clean)8062.52020--Available
FTTC Range B (Impacted)75.651.52015.6--Available
WBC ADSL 2+Up to 13--7.5 to 17.5Available
WBC ADSL 2+ Annex MUp to 13Up to 17.5 to 17.5Available
ADSL MaxUp to 6.5--5.5 to 8Available
WBC Fixed Rate2 ----Available
Other Offerings
FTTP on Demand33030--Available
Fibre Multicast------Available
Copper Multicast------Available
