Bt business line :BTHub5-c575.London E3
Dear Can you please fix this problem
Our Android device does not connect to bt broadband,
After Factory rest it worked for awhile and then it stops working,
it's not working with Samsung and Dell desktop.
can please fixed this problem
shoibul
Solved! Go to Solution.
This is a BT Residential forum. If you are a BT Business user you will need to post on the BT Business Forum where you should get the relevant help.
Welcome to the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
@shoibullms wrote:
We live at postcode , BTHub5- it’s busines broadband line ,We had same problems earlier WiFi not connected with Android device ,,it’s only connected with apple device,we have done ✅ factory reset and restart so many times ,fix it ple
Hi.
Please don't post personal details, edit your post to remove them.
Also you've posted before, and today in 2 different sub-forums (please don't multi-post).
The issue sounds like it's with your devices, nothing specifically that can be done "here". What android devices are you having problems with? Are you using only 5Ghz wireless?
As it is a business line you need to post on business forum https://business.forums.bt.com/
this is is a forum for residential connections
