robjo
Message 1 of 11
Re: BT Wifi not active on Smart Hub
I have the same problem had hub for about 4 months and still shows Bt wifi not active. Can you help?
10 REPLIES 10
Keith_Beddoe
Message 2 of 11
I have moved your post to a new thread, so you can get help from the community.
Have you checked the status of your BT Wifi by logging into MyBT to see if you are opted in?
Can you access other BT WiFi hotspots when you are away from your house?
robjo
Message 3 of 11
I have spoken to BT this morning they thought it was not opted in correctly. They said it should take four hours to update. No luck yet.
Keith_Beddoe
Message 4 of 11
What does it say when you login to MyBT, and look at your extras, can you see the BTWifi extra?
robjo
Message 5 of 11
Yep it shows active, however it has always shown that and I have been able to use BT WIFI away from home. It is just my home hub 6 that does not show active
Keith_Beddoe
Message 6 of 11
Its possible that attempts are being made to change the configuration of the hub, but for some reason they are failing.
Look for ppp1:TR69 ConnectionRequest: processing request from ACS
in the system log on this link.
http://192.168.1.254/0000013200/gui/#/technicalLog/eventlog
Set log filter to select TR69 category events only, otherwise you will never find them Smiley Wink
See if the connection attempts are failing.
PaddyB
Moderator
Moderator
Message 7 of 11
Hi @robjo,
I'll be able to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
robjo
Message 8 of 11
Hi Kieth
The log shows
15:12:34, 18 Dec.
ppp1:TR69 ConnectionRequest Failed
15:12:34, 18 Dec.
15:12:34, 18 Dec.
15:12:34, 18 Dec.
15:11:46, 18 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
15:11:45, 18 Dec.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
15:11:45, 18 Dec.
InformResponse:TR69 receiving message
15:11:45, 18 Dec.
ppp1:TR69 event found : 6 CONNECTION REQUEST
15:11:45, 18 Dec.
ppp1:TR69 event found : 4 VALUE CHANGE
15:11:44, 18 Dec.
ppp1:TR69 sending Inform message
15:11:43, 18 Dec.
15:11:43, 18 Dec.
15:11:41, 18 Dec.
15:11:41, 18 Dec.
ppp1:TR69 creating new session with ACS
15:11:39, 18 Dec.
Latest shows
16:50:51, 18 Dec.
16:50:51, 18 Dec.
regards
Rob
robjo
Message 9 of 11
Just to update Mod's. I have had replacement hub in place since before christmas and can confirm that BT wifi is still not active.
Rob
robjo
Message 10 of 11
Just wondering if John (MOD) has update for me, he was going to check over christmas period?
regards
Rob
