john46
Message 21 of 24
Re: BT infinity really slow speeds because high usage.
Post edited by poster
Open Link in New Tab
RSebire
Message 22 of 24
After entering my telephone number and trying to run the dsl test I receive ;
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line.
Webby
Message 23 of 24
I suggest posting on Reddit. Sounds like you'd be more welcome over there. See how much help you get 🙂
cgb70
Message 24 of 24
I came here when I had issues with slow speeds ,and gave the information that the forum guys ales for and now my issue seems to be resolved ,was due to high capacity so they moved me to a different vlan ,so far so good.Never had to speak to a person on the phone was fixed all through these forums.You would be wise to give them the info and let them help you !!!
