Heck13
Message 1 of 8
Re: BT line checker error - Mods help please!
Hi Olga.
@OlgaC wrote:
Hi audiruss,
I would like to lend a hand and try and get the database updated for you. Can you send me in your details using the "Contact The Mods" link found in my profile and we will go from there.
Thanks,
OlgaC
I have a similar issue. I am the only house on my street that cant get Infinity. The local engineer says that I am definitely connected to a cabinet. Can you try and get the OR database updated for me?
7 REPLIES 7
john46
Message 2 of 8
I have asked a forum moderator to help you they will post their contact link here
NeilO
Moderator
Moderator
Message 3 of 8
@Heck13 Welcome to the forum and thanks for posting, I've started you're own thread as the one you've posted on was quite old.  Can you enter your number on the Broadband checker and post the results if you are connected to a cabinet it will advise you the cabinet number at the top of the page. Make sure to remove your number when replying.
Heck13
Message 4 of 8
Thanks for the reply and setting up this post.
Telephone Number 0147861**** on Exchange PORTREE
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
ADSL MaxUp to 8--7 to 8Available--------
Fixed Rate----Available--------
NeilO
Moderator
Moderator
Message 5 of 8
@Heck13 after the exchange name did it mention which cabinet your line is served from?
Heck13
Message 6 of 8
@NeilO nothing about cabinets, although everyone else in my street is on Cabinet 2 and that is what I have been told my line is going to also.
NeilO
Moderator
Moderator
Message 7 of 8
@Heck13 We can get that checked further but if no cabinet it mentioned on the checker it might mean you are on an exchange only line.  Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Heck13
Message 8 of 8
Thank you. I've done that. The local engineer (small village) who installed my line says I'm definitely in cabinet 2. I actually used to have 2 lines - home and office - so am wondering if that has caused the issue as office line is now dead.
