on 26-09-2017 21h32
on 26-09-2017 21h35
You need to be within range of a BTWifi Hotspot before you will see it on your devices wifi list.
Once you are in range and see the BTWifi on the list you connect as per the following link.
https://www.btwifi.co.uk/help/login-with-bt/
