Hi i am in exactly the same situation as the OP. I am on exchange 3 in winchburgh but i havent been able to get more than 6mbs. how do i get to upgrade this? thanks
Solved! Go to Solution.
I'll be able to take a look at your connection and upgrade you to ADSL 2 if possible. You will more than like have to agree to a 12 month term in order to have the service upgraded.
You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
thanks. I have just sent a mesage with my details. please let me know if you need anything else.
Thank you for taking my call today. I've tested your connection and its looking good. Your sync speed has increased to 12824 Kbps and this has enable a profile of 11370 Kbps.
PaddyB
