RichardAllsopp
Message 1 of 15
Re: Being lied to about interleaving
Hi i am wanting interleaving switching off so my line Profile is fast i am suffering haveing it on interleaved as i play online games
14 REPLIES 14
imjolly
Message 2 of 15
I moved your post as the thread on which you posted was 2.5yrs old
can you post the the adsl stats from your router including connection time connection speed noise margin and errors
RichardAllsopp
Message 3 of 15
imjolly
Message 4 of 15
Your connection time is only 2+hrs was that a manual reset or router dropping connection. I ask as fast will make your line less stable  than your current interleaved setting
RichardAllsopp
Message 5 of 15
Just a Manual reset
imjolly
Message 6 of 15
The mods will post a contact us link and will change latency to fast
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
StuartH
Moderator
Moderator
Message 7 of 15
Hi Richardallsop
Send us an email using the contact the mods link in my profile we can request this change for you.
Stuart
RichardAllsopp
Message 8 of 15
I have sent you my details
4Horseman
Message 9 of 15
Good luck with keeping interleaving on fast, DLM will most likely change it back to interleaved after a week - which is what happened to me and now I'm being fobbed off with BT saying they can not lock my interlaving to fast although I had it locked for over 9 months!
john46
Message 10 of 15
wrong information there are 3 options on /off & locked interleaving will remain off if the line produces minimal errors and noise
