Message 1 of 5
Re: Broadband Keeps Disconnecting (BT Home Hub)
I'm having isses too, by hh 4 keeps disconecting and in the past 30 mins it must of disconected at least 10 times, goes off flashes orange, goes blue for a bit then goes off and keeps repeating.
4 REPLIES 4
Message 1 of 5
Moved:
Message 3 of 5
this is the speed test that is needed please http://speedtest.btwholesale.com/ once the first test is completed run the further diagnostics test and post back those results
Message 4 of 5
http://gyazo.com/280539d8248db7ba674dd621e40f9e3b 276 ping doesn't look good for you guys -.- http://gyazo.com/8ec3fe072dc7631624245dfc31bc259e tthis is the further diagnostics.
Message 5 of 5
i would suggest you try a ping test to bbc.co.uk using command prompt
