Message 1 of 2
Re: Broadband Speed Decrease
Me too i have the same Infinity 1, my 10 day stablization has passed and now the speeds r all over the place, i have same speeds issue and ip address keeps on changing
1 REPLY 1
Message 2 of 2
In order for forum member to help you need to post some information
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 Are you using the test socket with a new filter to eliminate problems with your setup and internal wiring
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
