Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi AndrewJ,
you might be be amused to know that I am in a similar situation to you back in 2012 with regards to British Telecom adsl; the BT line was faulty last year, (June 2014) but at this end of the road there are only two residential customers to complain.
After 50 minutes of arguing with know-all Indians, who threatened me (& probably my neighbour also) with a £100 charge if the faults turned out to be internal, we were eventually visited by some operatives from Openreach; they accepted that my microfilter was not to blame, and, with difficulty, eventually obtained authorisation to return and replace several lengths of twenty-five year oldcopper line, and they later installed an external 'waterproof' junction box.
However, during the last 8 months, rainwater has dripped quietly into the new junction box, and caused corrosion and a short circuit that has broken my favourite telephone and necessitated another Openreach visit.
The 'waterproof' junction box was presumably tested in the Atacama desert.
Anyway, no sign of an IP reset, and so we are stuck with 0.25 mbps for the foreseeable future.
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
I moved your post from the 2.5yr old thread to start your own and that way replies will be about your problem and avoid any confusion
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run btspeedtester (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
