HunterTheMunter
Message 1 of 6
Re: Bt infinity speed problems
Hi All
Ive not that long had BT SUPER FAST INFINITY 2!!!!! which i upgraded from my ADSL 2 (ssolid 20-22 down )
1. when ordering i was given from that day a line test and speed of 77-80 / 20
2. a 14 day cooling off period ( watch this ). 4 days before installation and a 10 day stabilization period ( Lock in)
3. line sync from router at 78 / 19
4. Throughput of 15-40* / 10-15. This it seams is perfectly normal speeds for super fast broadband according to bt.
* high occassonaly
Had several discussions with bt but going down the rout of changing the router. Failing this, down grading to a more stable package.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ41431750
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 05/07/14
4. Board version:BT Hub 5A
5. VDSL uptime:1 days, 00:42:27
6. Data rate:19999 / 79995
7. Maximum data rate:31468 / 100184
8. Noise margin:15.3 / 11.7
9. Line attenuation:0.0 / 12.3
10. Signal attenuation:0.0 / 12.3
11. Data sent/received:140.8 MB / 724.4 MB
12. Broadband username:bthomehub@btbroadband.com
5 REPLIES 5
HunterTheMunter
Message 2 of 6
LEAVES ON THE LINE maybe ¬¬
imjolly
Message 3 of 6
Can you run btspeedtester and when first test completes then run diagnostic test and post results. Should be done with wired connection
HunterTheMunter
Message 4 of 6
Sorry for the late reply but think it MAYbe solved. I ended up using serveral checkers which all gave different results, Thinkbroadband giving me the most consistent reading of 74 / 18 so checked a few 1GB test files which were pulling down at between 8-9 mb. What I have worked out is that the wireless throughput on my HH5 is surprisingly poor..
Thanls for the speedy reply tho.
imjolly
Message 5 of 6
Apart from a few posts you will find that wifi is always lower then wired and sometimes considerably lower
gg30340
Message 6 of 6
Are you sure you are not confusing Megabytes (MB) with Megabits (Mb).
People often assume that a download speed of 1 Megabit per second (1 Mbps) will allow them to download a 1 Megabyte file in one second. This is not the case, a Megabit is 1/8 as big as a Megabyte, meaning that to download a 1MB file in 1 second you would need a connection of 8Mbps.
Therefore  if you are downloading 8-9MBs multiply by 8 and you get 64- 72Mbps
