hunter_jim
Message 1 of 2
Re: Bt sport chromecast
Recently had BT Infinity with Smarthub installed. The Chromecasts would then not work properly. Traced the problem to the VPN service on my smartphone. Turned VPN off when connecting to Chromecasts and all is now well. Problem solved.
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Hi @hunter_jim and welcome.
Thanks for posting. Appreciate you taking time to do that.
Cheers
David
