Message 1 of 8
Re: Can I upgrade from ADSL Max to ADSL2+?
Hi , I have the exact same requirement , I tried calling the sales team but they are advising I have already been upgraded , my Home Hub hasnt changed the connection speed to eflect there has been a change .
Can you verify for me to confirm that ADSL2 is now enabled and I should be connecting at 12meg please?
7 REPLIES 7
Message 2 of 8
I get this eply to that link
You do not have sufficient privileges for this resource or its parent to perform this action.
Should it be working ?
Message 3 of 8
no it is a deleted post as it shows in the link
Message 4 of 8
Doh ! so it is .. soz Smiley Embarassed
Moderator
Moderator
Message 5 of 8
Hi @RobSpence,
Thanks for posting. Can you enter your number in the checker and post the results? Please remove the number before posting.
Also try the speed test and post those results and we'll check this for you.
Cheers
David
Message 6 of 8
Sure , @DavidMthanks for following up heres the output from the checker
Telephone Number 01506XXXXXX on Exchange WINCHBURGH is served by Cabinet 3
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+Up to 12--7 to 17Available----
WBC ADSL 2+ Annex MUp to 12Up to 17 to 17Available----
ADSL MaxUp to 8--7 to 8Available----
Fixed Rate2 ----Available----
and from the speed checker
Broadband Speed Test Results
Download Speed (Mbps)  6.56
Upload Speed (Mbps) 0.38
Ping Latency (ms)  47.88
Moderator
Moderator
Message 7 of 8
Thanks for posting the details @RobSpence.
Can you please send me over your details and I'll get this sorted for you. You'll get the contact the moderators link in my profile.
Cheers
David
Moderator
Moderator
Message 8 of 8
Hi @RobSpence,
Thanks for taking my call today. I'm glad I was able to get this sorted for you. Post back if you have any other problems and we'll be happy to help.
Cheers
David
