Hi Gemma
I have just had a new UHD box installed and I can't get catch up. All the extra channels work fine. Can you help?
MJ1000
Solved! Go to Solution.
@maddenjasper1000 I've started your own thread as the OP's issue has been sorted by our TV team. If you send over your BT account info using the 'click here to contact the mods' link in my forum profile we'll be happy to help you get that fixed. You can find the link by clicking on my username.
Neil
