Hi I am trying to connect a Samsung ML210 laser to my USB connection on a Smart Hub (HH6). Windows detects the printer and comes up with list of drivers, I install driver. Also changed port details to your instructions. However when sending a test page to the printer it just comes up as an error. Anyone tried printing from a HH6.
Mike
Solved! Go to Solution.
I have moved your post to start a new thread as the thread you are posting on is 8 years old. Try enabling SMB1 on your Windows machine. See http://www.thewindowsclub.com/disable-smb1-windows
I probably disabled that as belt and braces so as not to be infected by Wanacrypt 🙂
Don't blame you, unfortunately the HHs use SMB1
