Pulbara
Message 1 of 4
Re: Connection Problems
lHi iv been told that i have a '' Closed '' issue,can somebody please tell me what that means, and also what needs to be done to 'Fix' it,Thanks 🙂
3 REPLIES 3
JohnC2
Moderator
Moderator
Message 2 of 4
Hi @Pulbara If you have raised a fault it most likely means that the fault is closed and a new fault report would need to be opened.
If you are having a problem with your connection why not create your own thread and outline the problem and the community will be able to help you.
Cheers
John
Pulbara
Message 3 of 4
Thank you so much for information on my connection issues,ireally appreciate your help 🙂 I dont know if i mentioned that i am really naff at tecky stuff and im sorry to say that i dont understand what i need to do step by painful step :((    Many Many Thanks
john46
Message 4 of 4
