imjolly
Message 11 of 106
Re: Download times abysmal
then probably need to change the channel on your router as maybe a neighbour has infinity with new hub and on same channel as you
you need to enter assuming you have hub 192.168.1.254 into your browser, then the admin passowrd then go to wireless and chnage wireless from automatic to manual then select a diiferent channel number
bullshot
Message 12 of 106
It dropped again 3 times in 36 mins...connected and dropped 2 mins later.....re neighbour with Infinity....might be right as a young techie bloke lives next door and he is with BT and was waiting for Infinity to be activated, so that would make sense....genius!!!! Must go to the supermarket now , hubby getting the car out , will try and understand the changing channel info when I get back.....trying to do all this whilst sorting out a curtain problem with John Lewis.....need to lie down in a dark room methinks.
bullshot
Message 13 of 106
The number is 192.168.1.78. What do I do now , please?
bullshot
Message 14 of 106
Speed now 12.1 but dropping connection still
imjolly
Message 15 of 106
did you enter 192.168.1.254 into your browser no www in front.  that should take you to hub manager where you need to enter the admin password which is probably on hub.  then go to wireless
does this help http://bt.custhelp.com/app/answers/detail/a_id/14094/kw/change%20wireless%20channel/c/346,407,410
bullshot
Message 16 of 106
Is that my IP address......?
bullshot
Message 17 of 106
Where do I check the number you posted...
imjolly
Message 18 of 106
that is your router address so you enter 192.168.1.254 not www.192.168.1.254
enter in browser address bar
bullshot
Message 19 of 106
Is it on the hub?
imjolly
Message 20 of 106
use this link http://bthomehub.home
